Siebel Object Interfaces Reference > Interfaces Reference > Business Component Events > BusComp_PreInvokeMethod EventThe PreInvokeMethod event is called before a specialized method is invoked on the business component. SyntaxBusComp_PreInvokeMethod(methodName) ReturnsContinueOperation or CancelOperation UsageThe PreInvokeMethod event is called just before a specialized method is invoked on the business component. Specialized methods are methods based on applet or business component classes other than CSSFrame and CSSBusComp, respectively, that is, specialized classes. CancelOperation stops the execution of the underlying Siebel code associated with the event. However, if there is code in the same script following CancelOperation, that code runs regardless of the CancelOperation. Used With |
Siebel Object Interfaces Reference |
