Siebel Object Interfaces Reference > Interfaces Reference > Business Component Events >
BusComp_PreQuery Event
The PreQuery event is called before query execution.
Syntax
BusComp_PreQuery
Argument
Description
Not applicable
Returns
ContinueOperation or CancelOperation
Usage
This event may be used to modify the search criteria or to restrict the execution of certain queries.
CancelOperation stops the execution of the underlying Siebel code associated with the event. However, if there is code in the same script following CancelOperation, that code runs regardless of the CancelOperation.
Used With
Server Script
Example
The following example is in Siebel VB:
Function BusComp_PreQuery() As Integer
   Dim strPosition As String
   Dim strSearchSpec As String
   Dim intReturn As Integer
   intReturn = ContinueOperation
   strPosition = TheApplication.PositionName
   strSearchSpec = Me.GetSearchSpec("Owned By")
   If strPosition <> "System Administrator" Then
      if Len(strSearchSpec) = 0 or InStr(strSearchSpec,
         strPosition) = 0 Then
         Me.SetSearchSpec "Owned By", strPosition
      end if
   End if
   BusComp_PreQuery = intReturn
End Function
