Table 71. Application Methods Syntax Summary
ActiveBusObject Method |
Returns the business object for the business component for the active applet. |
var busObject; busObject = TheApplication().ActiveBusObject();
ActiveViewName Method |
Returns the name of the active view. |
var sView; sView = TheApplication().ActiveViewName();
CurrencyCode Method |
Returns the three-letter operating currency code. |
var sCur; sCur = TheApplication().CurrencyCode();
GetBusObject Method |
Instantiates and returns a new instance of the business object specified in the argument. |
var myBusObject; myBusObject = TheApplication().GetBusObject( BusObjectName);
Name Method |
Returns the name of the application. |
var name; name = TheApplication().Name();
GetService Method |
Instantiates and returns a new instance of the service specified in the argument. |
var Service; Service = TheApplication().GetService(serviceName);
GetSharedGlobal Method |
Gets the shared user-defined global variables. |
var sName; sName = TheApplication().GetSharedGlobal(varName);
GotoView Method |
Activates the named view and its business object. |
TheApplication().GotoView( viewName,[BusinessObject]);
InvokeMethod Method |
Calls the named specialized method. |
TheApplication().InvokeMethod( methodName, methodArg1, methodArg2,..., methodArgn);
LoginId Method |
Returns the login ID of the user who started the Siebel application. |
var sID; sID = TheApplication().LoginId();
LoginName Method |
Returns the login name of the user who started the Siebel application. |
var sUser; sUser = TheApplication().LoginName();
NewPropertySet Method |
Constructs and returns a new property set object. |
var oPropSet; oPropSet = TheApplication().NewPropertySet();
PositionId Method |
Returns the position ID that describes the user's current position. |
var sRow; sRow = TheApplication().PositionId();
PositionName Method |
Returns the position name of the user's current position. |
var sPosition; sPosition = TheApplication().PositionName();
RaiseError Method |
Raises a scripting error message to the browser. The error code is a canonical number. |
var keyVal; var arg1 ...; TheApplication().RaiseError(keyVal, arg1, ...);
RaiseErrorText Method |
Raises a scripting error message to the browser. The error text is the specified literal string. |
var message; TheApplication().RaiseErrorText(message);
SetPositionId Method |
Sets the active position to the position ID specified in the argument. |
var success; success = TheApplication().SetPositionId(posId);
SetPositionName Method |
Sets the active position to the position name specified in the argument. Returns a Boolean value indicating whether the method succeeded. |
var success; success = TheApplication().SetPositionName(posName);
SetProfileAttr Method |
Used in personalization to assign values to attributes in a user profile. |
TheApplication().SetProfileAttr(name, value);
SetSharedGlobal Method |
Sets a shared user-defined global variable. |
TheApplication().SetSharedGlobal(varName, value);
Trace Method |
Appends a message to the trace file. |
TheApplication().Trace(message);
TraceOff Method |
Turns off the tracing started by TraceOn. |
TheApplication().TraceOff();
TraceOn Method |
Turns tracing on. |
TheApplication().TraceOn(filename, type, selection);
