Siebel Order Management Guide Addendum for Industry Applications > Workflows for Employee Asset-Based Ordering for Industry Applications > Workflows for Enrollment >
CUT eSales - PC Prepare Cart Process
This workflow allows the user save the current shopping cart or discard the contents before adding the product selected from the quotes generated by the Price Comparison process.
This workflow is shown in Figure 17.
This workflow is invoked as a subprocess of the CUT eSales - PC Enrollment Process workflow.
NOTE:  This workflow is used only for customer applications. It is documented in this chapter because the workflow that calls it is used for both employee and customer applications.
Figure 17. CUT eSales - PC Prepare Cart Process
Click for full size image
Workflow Description. This workflow:
  1. Loads the current shopping cart and displays the Save Cart Confirmation view.
  2. If the user chooses Save, saves the cart.
  3. If the user chooses Discard, discards the cart.
  4. If the user chooses Cancel, displays the CUT Opportunity PC Price Comparison View (eSales) and terminates the calling workflow.
Associated Business Service Methods. The following table shows the steps in this workflow that calls a business service method.
Workflow Step
Method Called
In Business Service
Save Cart as Quote
SaveCartAsQuote
Shopping Service
Discard Cart
DiscardCart
Shopping Service
Go Back to PC Comparison View
GotoView
CUT OET Service
Siebel Order Management Guide Addendum for Industry Applications Copyright © 2009, Oracle and/or its affiliates. All rights reserved. Legal Notices.
