Siebel Order Management Guide Addendum for Industry Applications > Using Network Ordering > Process of Upgrading Bandwidth at Network Sites > Upgrading the Bandwidth at a Network SiteTo upgrade bandwidth at an existing network site, you must increase the speed of the network node product, for example the port speed of the Frame Relay Port product. This task is a step in Process of Upgrading Bandwidth at Network Sites. NOTE: If you modelled all of your network components as simple products, instead of using this procedure and the following procedure, you can simply navigate to the All Network Elements view of the Networks screen and select both the Network Node and the Network Connection you wish to upgrade Once the two or more items have been selected, click Modify and a new change quote will appear with all selected items as line items. Then navigate to the Attributes view tab and upgrade accordingly. To modify the access at a network site
Siebel Order Management Guide Addendum for Industry Applications | Copyright © 2009, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
