Siebel Order Management Guide Addendum for Industry Applications > Using Network Ordering > Process of Upgrading Bandwidth at Network Sites >
Upgrading the Bandwidth of a Network Connection
You use the same change quote to upgrade the Committed Information Rate (CIR) on a network connection.
This task is a step in Process of Upgrading Bandwidth at Network Sites.
To upgrade the bandwidth of a network connection
  1. After modifying the speed of the node, click Back to return to the Connections view.
  2. Select the network connection that you want to upgrade and view the current CIR for this connection.
  3. Click Modify
    You enter a Configurator session where you can increase the speed of the network connection CIR.
  4. Click Done.
    The change quote appears with a second line item added.
Siebel Order Management Guide Addendum for Industry Applications Copyright © 2009, Oracle and/or its affiliates. All rights reserved. Legal Notices.
