Siebel Order Management Guide Addendum for Industry Applications > Setting Up Network Ordering > About Network OrderingThe network order entry process is used to configure products that are too large to be configured in real time with Siebel Configurator. Large telecommunications networks might have 500 nodes and 1,000 connections, with each of these components having about 30 attributes. Siebel Configurator can be used for small telecommunications networks, up to about one-hundredth of the size mentioned in the previous paragraph. However, Configurator validates configuration in real time, and configuring large networks requires so much processing that real-time validation is not possible. Network order entry solves this problem by:
For example, Figure 39 illustrates part of a network that uses a frame relay as its network product and several ports and PVCs as its components. The network and its components are all defined as separate products. A foreign key field in the component products relates them to the network product. Configurator can be used to validate the configuration of the individual network product and component products. The Compound Product Validation Engine validates the network across products. The Compound Product Validation Engine validates the network across components by applying rules, such as:
Network order entry partitions the network into multiple components: |
Siebel Order Management Guide Addendum for Industry Applications | Copyright © 2009, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
