Siebel Order Management Infrastructure Guide > Copy Service > Copy Service Methods >
SetupLineNumbers Method
SetupLineNumbers method updates the line numbers for the Line Item being customized corresponding to the CxObj.
Syntax
SetupLineNumbers <inputArgs>, <outputArgs>
Input Arguments
  • HeaderIntCompName: Header Integration Component Name.
  • Integration Object Name: This is the integration object name to use to load the object through EAI.
  • InstanceCollectionName: A string indicating the name of the instance collection.
  • InstanceName: A string indicating the name of the instance.
  • Line Number Field: Line number field.
  • LineItemIntCompName: Line Item Integration Component Name.
  • Row Id:Line Item Id.
Usage
SetupLineNumbers updates the line numbers for the Line Item being customized corresponding to the CxObj.
Invoked From
Browser Script, COM Data Control, COM Data Server, Server Script, Java Data Bean, Siebel Mobile Web Client Automation Server
Siebel Order Management Infrastructure Guide Copyright © 2008, Oracle and/or its affiliates. All rights reserved. Legal Notices.
