Siebel Order Management Infrastructure Guide > Product Selection and Pricing Engine > Row Set Transformation Toolkit Methods >
Hierarchical Method
The Hierarchical method processes a hierarchy of input rows from top to bottom or bottom to top. For example, it could be used for a customizable product price roll-up. See Table 18 for further description.
Arguments
Table 18. Hierarchical Method Arguments
Argument
Description
Context
Optional. Property set of variables shared across all rows.
Row Set
The set of rows to process.
Output Row Set
Optional. The property set used for output.
Process Condition
A Boolean condition that is evaluated to determine whether to process each row.
Row Id Field
The ID field in {Row} (example: Id).
Parent Field
The name of the parent ID field that defines the hierarchy in the input row set.
Direction
Up or Down. Indicates the direction of traversal of the tree.
On Top Row [1..20]
Actions to perform on the top row in each tree.
On Row [1..20]
Actions to perform on every row.
On Parent Row [1..20]
Actions to perform on every row that has children beneath it in a tree.
On Leaf Row [1..20]
Actions to perform on rows that have no children.
Example
Figure 27 shows an example of arguments for a PSP procedure step named Customizable Product Roll-Up, which uses the Hierarchical method.
Figure 27. Example of Arguments for Hierarchical Method
Click for full size image
Siebel Order Management Infrastructure Guide Copyright © 2008, Oracle and/or its affiliates. All rights reserved. Legal Notices.
