Table 22. Rule Set Look-Up Method Arguments
Context |
Optional. Property set of variables shared across all rows. |
Row Set |
The set of rows to process. |
Output Row Set |
Optional. The property set used for output. |
Process Condition |
A Boolean condition that is evaluated to determine whether to process each row. |
Business Object |
The business object to query to retrieve the rules. |
Business Component |
The business component to query to retrieve the rules. |
Search Specification |
A search expression comprised of business component fields, literals, and variable values from {Context} and {Row}. For example: [Required Flag] = 'Y'
In Memory Search Specification |
Optional. Additional terms that are ANDed with the Search Specification. The In Memory Search Specification is executed in memory. This can be used only if Cache Enabled = Y. |
Cache Search Specification |
Optional. Additional terms that define the key values for the Level 1 cache (for example: [Price List Id] = {Row.Price List Id} ). See About PSP Cache. |
Sort Specification |
Optional. A comma-separated list of business component fields used to sort the query result. |
Cache Enabled |
Optional. Specifies whether to cache query results. Y or N. The default is N. |
Rule Set Field |
The field in the business component that groups the rules into a rule set (for example: Promotion Id, Bundle Id). |
Row Join Field |
The field in the {Row} that is joined to a matching rule (example: Product Id). This transform tests all rows that join to see if the rule expression is satisfied. |
Rule Join Field |
The field in the rule business component that is joined to a matching {Row} (for example: Product Id). |
Rule Expression |
Optional. A Boolean expression that defines whether a rule is satisfied by a row (for example: {Match.Min Qty} = 0) OR {Match.Min Qty} <= {Row.Qty} ). |
Pass Only If All Rules Match |
Y or N. This indicates whether to execute the On Pass ... conditions only if all rules in a rule set pass, or whether to execute those conditions for any rule that is satisfied. |
Row Set Sort Specification |
Optional. A comma-separated list of {Row} field names that determine the sequence in which rows in {Row Set} are processed as they are compared with the rules. This transform is used to make sure that the highest value item is given away in a buy-one-get-one-free scenario. This transform is required for backward compatibility. |
Rule Sets |
A property set containing a list of rule sets to test. Each child property set can contain the following fields:
- [Rule Set Sequence Id] (optional)
- [Sequence] (optional)
- A value for the Rule Set Field (example: [Bundle Id])
- [Next Sequence on Fail] (optional)
For example, the list of promotions that requires integrity checking or the list of bundles associated with the current price list. If the [Next Sequence on Pass] field is populated, then the Rule Sets transform skips to that value of [Sequence] if the current rule set passes. If the [Next Sequence on Fail] field is populated, then the transform skips to that value of [Sequence] if the current rule set fails. NOTE: There can be multiple sequences of rule sets in the Rule Sets property set. Individual rule-set sequences are identified by the optional [Rule Set Sequence Id] field.
Attributes of the rule set being evaluated are exposed to action syntax as {Rule Set.Value}. |
On Pass First Match |
Occurs for the first row in the row set that matches a rule in a rule set for which the evaluation criteria are satisfied. For 'On Pass ... [Rule]' conditions, {Row} and {Match} variables are available to actions. |
On Pass Match |
Occurs for every row in the row set that matches a rule in a rule set for which the evaluation criteria are satisfied. For On Pass ... [Rule] conditions, {Row} and {Match} variables are available to actions. |
On Pass Last Match |
Occurs for the last row in the row set that matches a rule in a rule set for which the evaluation criteria are satisfied. For On Pass ... [Rule] conditions, {Row} and {Match} variables are available to actions. |
On Fail First Rule |
Occurs for the first rule not satisfied in a failed rule set. NOTE: For On Fail ... [Rule] conditions, only the {Match} variable is available to actions.
On Fail Rule |
Occurs for each rule that was not satisfied in a failed rule set. |
On Fail Last Rule |
Occurs for the last rule that was not satisfied in a failed rule set. |
