Siebel Order Management Infrastructure Guide > Signals > Signals Migration Between EnvironmentsSignals can be moved between environments, such as from the development environment to the test environment, by using the Application Deployment Manager (ADM). For information about using ADM, see Siebel Application Deployment Manager Guide. You can also export a specific version of a signal using the Export Version applet menu in the Signal Version list. To import a signal, navigate to the Administration - Products screen, then Joint Workspace view. This is a joint workspace for all types of versioned objects (signals, variable maps, products, product attributes, and so on). For more information on import/export, see Product Administration Guide. |
Siebel Order Management Infrastructure Guide | Copyright © 2008, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
