Pricing Administration Guide > Creating Discount Matrices > About Configuring Discount MatricesThe criteria, calculation, and result dimensions that are available for each discount matrix type are the ones that are most commonly used for that type of adjustment. However, your business model may require you to use additional dimensions that are not available by default. To make these additional dimensions available, you can configure the application with Siebel Tools. For more information about Siebel Tools, see Using Siebel Tools. To make additional dimensions available, you must understand the tables used to store the discount matrix data, which are shown in Figure 13. Discount matrix fields are stored in the following tables:
To extend the available criteria, calculation, or result dimensions, you may add columns to any or all of these tables. The following topics include instructions for configuring discount matrices: |
Pricing Administration Guide |
