Pricing Administration Guide > Creating Attribute Adjustments > Process of Creating an Attribute Adjustment >
Adding an Attribute Adjustment Record
The Attribute Adjustment record holds general information about the attribute adjustment. This task is a step in Process of Creating an Attribute Adjustment. To create an attribute adjustment record
- Navigate to the Administration - Pricing screen > Attribute Adjustments view.
- In the Attribute Adjustments list, add a new record and complete the necessary fields.
Some fields are described in the following table.
Name |
Enter a name for the attribute adjustment. |
Class |
If product attributes affect the price, select the class where these attributes are defined. NOTE: If you are setting up attribute adjustments based on nonproduct attributes such as Account Type, Region, and so on, leave this field blank.
Type |
Select the type of the adjustment. Options are:
- Single. Each attribute (condition dimension) affects the price in isolation from the others.
- Multiple. The price adjustment depends on a combination of attributes (condition dimensions).
For more information, see Single and Multiple Type Attribute Adjustments. |
Display Error |
Select this check box if you want the application to display an error message when a user selects an invalid combination of attributes for the attribute pricing. The combination is considered invalid if it is not included in the list of rules. For more information about how to use this field, see Preventing Users from Selecting Invalid Combinations of Attributes. NOTE: This field is used only for attribute pricing. Do not select it if you are using attribute adjustment for some advanced use instead of for attribute pricing.
Effective From and Effective To |
Enter the start date and end date of the time period when this attribute adjustment is active. |
