Pricing Administration Guide > Siebel Pricer Technical Reference > Miscellaneous Pricing Workflows > PSP Waterfall Synch to DB WorkflowThis workflow writes waterfall records to the database according to input from the data map object. Table 27 lists describes the step in the PSP Waterfall Synch to DB Workflow workflow with the business service and method that is called. |
Pricing Administration Guide |
