Product Administration Guide > Siebel Configurator Technical Reference > Enabling Auto MatchWhen a new version of a customizable product is released, Auto Match adjusts the configuration of the product in a quote, asset, or order to reflect the changes. Auto Match is disabled by default. For Web Client users, you turn Auto Match on by setting its server parameter to TRUE. Table 44 shows the Auto Match server parameter.
For Dedicated Web Client users (also called mobile client users), add the following entries to the configuration file used to start the application, for example Siebel.cfg. |
Product Administration Guide | Copyright © 2011, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
