Product Administration Guide > Creating Validation Rules for Customizable Products > Setting Up Product Validation Using Custom Validation ServicesTo create product validation rules, perform the following tasks:
Creating the Customizable Product for ValidationValidation rules only work on products that have been defined as components of a product with components. They use the Instance ID of the customizable product as the key to retrieve products to validate. As the first step in creating validation rules, define a product with components whose components include all the products that the rules will apply to. For more information, see Designing Products with Components. Creating Messages for Product ValidationIf your custom business service uses Universal Messaging Service, you must use the Administration - Application screen, then the Message Types view to define the error messages that the product validation rule will display. For more information about defining messages, see Siebel Order Management Infrastructure Guide. To create the messages for product validation
Creating a Custom Business Service for Product ValidationYou can create your own business services to solve specialized business problems, such as the problem described in Scenario for Product Validation Using Custom Validation Services. This business service should follow the guidelines described in About Creating Custom Rule Checkers. For more information about creating business services, see Siebel eScript Language Reference and Siebel VB Language Reference. Adding the Validation Services RecordThe Validation Services record contains the name of the validation business service to call. In this case, you use it to call the custom business service that you created.
Product Administration Guide | Copyright © 2011, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
