Siebel Public Sector Guide >
Getting Started with Siebel Public Sector
This chapter lists the applications administration tasks that are specific to Siebel Public Sector. It includes the following topics:
Use this chapter in combination with Applications Administration Guide which includes information on the setup tasks that are common to all Siebel Business Applications such as using license keys, defining employees, and defining your agency's structure. Applications Administration Guide also provides the information that you need to perform data administration and other administration tasks.
Some tasks discussed in this chapter may replace the corresponding tasks in the Applications Administration Guide, whereas others may be additional tasks. Make sure you review Table 3 before following the procedures in Applications Administration Guide.
This guide assumes that you have already installed Siebel Public Sector. If you have not installed the application, review the Server Installation and Upgrade section of Siebel Bookshelf and click the links to the guides that are relevant to your agency's implementation.
For instructions on how to create the Siebel Administrator account that is used to perform the administrative procedures described in this guide, see the Siebel Installation Guide for the operating system you are using.
