Table 3. Administrative Tasks for Siebel Public Sector
Activity Plan templates |
If your organization uses activity plans with predefined activities, these templates must be set up. When creating a new Activity Template to use with Cases, the Type value must be set to HLS Case. |
Applications Administration Guide |
Adobe Forms Integration |
If your organization wants to automatically populate PDF forms, such as citizenship and immigration applications, with Siebel data, an integration object must be selected or created, a schema generated, and the XML schema mapped to the PDF form. |
Setting Up and Using Adobe Forms Integration. |
Assessment templates |
If your organization mandates specific assessment criteria, assessment templates with attributes must be set up. When creating a new Case Assessment template, set the Type value to HLS Case. |
Assignment Manager |
If your organization wants to automate the assignment of case- and immigration-related activities, you can use Assignment Manager's predefined assignment objects. |
Assignment Manager and Siebel Public Sector Siebel Assignment Manager Administration Guide |
Business Processes (Workflow) |
If your organization wants to design and implement automatic business process flows, you can use the Business Process Designer. Some predefined workflow processes must be activated. |
Activating Public Sector Workflows. See also Siebel Business Process Designer Administration Guide |
Data loading and integration |
If your organization wants to integrate with other database applications or perform periodic batch imports and exports of data between the Siebel database and other applications, you can perform these tasks using Siebel EIM. Using EIM, you can work with the following objects and their components:
- Cases
- Diseases
- Groups
- Medications
- Suspects
- Incidents
Siebel Enterprise Integration Manager Administration Guide Integration Platform Technologies: Siebel Enterprise Application Integration Transports and Interfaces: Siebel Enterprise Application Integration Business Processes and Rules: Siebel Enterprise Application Integration Siebel Object Interfaces Reference |
Home Page image |
If your organization wants to maintain a graphic displayed to users on the Public Sector application home page, you can perform this task using the Home Page Image Administration screen. |
Adding an Image to the Home Page Warning Level Indicator |
iHelp |
If your organization wants to set up iHelp to provide real-time task assistance to users, you can use the iHelp tool to embed view navigation links and highlight fields and buttons on the view that are associated with each step of the task. |
Applications Administration Guide (developing and administering iHelp) Fundamentals (using iHelp) |
Lists of Values (LOVs) |
If your organization wants to create standard LOVs for Case Type and Stage, and Case Status and Sub-Status values, you can create and modify lists of values. |
Mobile Synchronization |
If mobile devices are used by your organization's personnel, the following objects and child components should be activated on the mobile devices with the following visibilities:
- Cases (My and Team's)
- Groups (My and Team's)
- Suspects (My and Team's)
- Diseases (My and Team's)
- Medications (All)
Each object should have partial visibility to all child components. |
Siebel Service Handheld Guide |
Quickfill templates |
If your organization wants to create standard templates for commonly used Incident and Case types, you can create Quick Fill templates. End users can apply templates from the Case and Incident forms by clicking the menu button in the form and choosing Apply Template, Save as Template, New from Template, or New from Last Template. |
Responsibilities |
If your organization wants to restrict the visibility of views based on each employee's responsibilities, you can assign responsibilities for each user. For a list of default views associated with each responsibility, see Public Sector Responsibilities and Views. |
Security Guide for Siebel Business Applications Applications Administration Guide |
Siebel Tools |
If your organization wants to change or create new application fields or field properties, change colors and controls in the application, and add or remove applets, you can perform these tasks using Siebel Tools. |
Configuring Siebel Business Applications Siebel Developer's Reference Siebel Tools Online Help Using Siebel Tools |
Training Administration |
If your organization wants to set up Training courses for users, you can perform these tasks using Siebel Training. |
Siebel Training Guide |
