This appendix contains a table that provides an overview of the differences between the docking objects in Siebel 7.7 and Siebel 7.5.
Routing Definition Differences in Docking Objects
Table 32 compares the routing definition differences between Siebel 7.5 and Siebel 7.7 docking objects, and lists new ones for Siebel 7.7. The table provides a comparison of pairs of docking objects between the two versions, or identifies new docking objects for Siebel 7.7. To read Table 32 use the following:
  • If the Version field of a row reads 7.5, compare it with the 7.7 row immediately below it.
  • If the Version field of a row reads 7.7 and the Version field of the row immediately above it also reads 7.7, a docking object is new in Siebel 7.7.
Table 32.  Docking Comparison - Docking Object Differences
Version
Docking Object
Visibility Level
Primary Table
DO Active?
7.7
ActivityWarehouseHierarchy
Private
S_EVT_ACT_WHIR
Y
7.7
ApprovalLevel
Enterprise
S_FN_APPR
Y
7.5
AssignGroup
Limited
S_ASGN_GRP
Y
7.7
AssignGroup
Enterprise
S_ASGN_GRP
Y
7.5
Audit Log
Private
S_AUDIT_ITEM
Y
7.7
Audit Log
Limited
S_AUDIT_ITEM
Y
7.5
Audit Trail
Private
S_AUDIT_TRAIL
Y
7.7
Audit Trail
Limited
S_AUDIT_TRAIL
Y
7.7
Barcode
Limited
S_BARCODE
Y
7.7
Barcode Enable
Limited
S_BCODE_ENABLE
Y
7.5
BusComp Audit
Limited
S_AUDIT_BUSCOMP
Y
7.7
BusComp Audit
Enterprise
S_AUDIT_BUSCOMP
Y
7.7
CFGUIGrpItem
Enterprise
S_CFG_UIGRP_IT
Y
7.7
CM MessageStatusTracking
Private
S_CM_MSG_STAT
Y
7.5
CalendarSharing
Limited
S_EMP_APPT
Y
7.7
CalendarSharing
Limited
S_EMP_APPT
N
7.7
CampListOutput
Private
S_CAMP_LSTOUTPT
Y
7.7
CommInboundEvent
Private
S_CM_INBND_EVT
Y
7.7
CompPlan Employee
Private
S_CP_EMP_PER
Y
7.7
CompatibilityMatrix
Limited
S_PRODCOMP_MTRX
Y
7.5
ContactProduct
Limited
S_CON_PRDINT
Y
7.7
ContactProduct
Limited
S_CON_PRDINT
N
7.7
ContactSyncSchd
Private
S_CON_SYNC_SCHD
Y
7.7
ContainerTxn
Private
S_IC_ACHV_TXN
Y
7.7
DMAP
Enterprise
S_BUSOBJ_DMAP
Y
7.7
DataValidation
Private
S_VALDN_RL_SET
Y
7.7
DispatchBoardLog
Private
S_DSP_BRD_LOG
Y
7.7
DockRequestRecord
Private
S_DOCK_REQ_REC
Y
7.7
DockTimeFilter
Enterprise
S_DOCK_TM_FLTR
Y
7.7
DynamicMatrix
Limited
S_DYN_PMTRX
Y
7.5
EAIBatch
Private
S_EAI_BATCH
Y
7.7
EAIBatch
Private
S_EAI_BATCH
N
7.7
EMTDataSet
Private
S_EMT_DATA_SET
Y
7.7
EMTObject
Private
S_EMT_OBJECT
Y
7.7
EMTSession
Private
S_EMT_SESSION
Y
7.7
EMTSessnItm
Private
S_EMT_SESSN_ITM
Y
7.7
EligibilityMatrix
Limited
S_PRODELIG_MTRX
Y
7.7
EmailResponseTime
Private
S_EM_RESP_TM
Y
7.7
Employee Position Period
Private
S_EMP_POSTN_PD
Y
7.7
ExcelIntegration
Limited
S_XL_VIEW_MAP
Y
7.7
Handheld Admin Application
Limited
S_MOBILE_APPL
Y
7.7
Handheld Admin Buscomp Filter
Limited
S_HH_BCFILTER
Y
7.7
Handheld Admin Busobj Filter
Limited
S_HH_BOFILTER
Y
7.7
Handheld Admin Setting
Limited
S_HH_SETTING
Y
7.7
Handheld Admin Summary
Limited
S_HH_SYNC_SUM
Y
7.7
Handheld Conflict Admin
Limited
S_HH_TXN_ERR
Y
7.7
ICSrvrTask
Private
S_IC_SRVR_REQ
Y
7.7
ICUserProperty
Private
S_IC_USER_PROP
Y
7.7
ISSCfgRuleNode
Private
S_ISS_CFRL_NODE
Y
7.7
ISSCfgServer
Private
S_ISS_CFG_SRVR
Y
7.7
ISSCfgValdtn
Private
S_ISS_CFG_VALDN
Y
7.7
ISSCfgValdtnScenario
Private
S_ISS_CFG_VALSC
Y
7.7
InvoicableCharge
Limited
S_INVOICE_CHRG
Y
7.7
InvoiceConsolidationPlan
Private
S_INVCNSLD_PLN
Y
7.7
InvoiceSignature
Private
S_INVOICE_SIGN
Y
7.7
JWS
Private
S_ISS_JWS
Y
7.7
LessonBasedURL
Private
S_CRSE_LSN_URL
Y
7.7
MSGControlTable
Private
S_MSG_CONTROL
Y
7.5
MSProjectIntegration
Enterprise
S_MPP_MAP
Y
7.7
Limited
S_MPP_MAP
Y
7.7
MaketingBudgetReq
Limited
S_MKTG_BDGT_REQ
Y
7.7
MarketingGoalTmpl
Private
S_SRC_GOAL_TMPL
Y
7.7
MarketingServerTask
Private
S_MKTG_SRVR_TSK
Y
7.5
MergeLog
Limited
S_MERGE_LOG
Y
7.7
MergeLog
Private
S_MERGE_LOG
Y
7.7
OMTempTable
Private
S_OM_TEMP
Y
7.5
OnLink Category
Private
S_ONL_CATEGORY
Y
7.7
OnLink Category
Limited
S_ONL_CATEGORY
Y
7.5
OnLink Object
Private
S_ONL_OBJECT
Y
7.7
OnLink Object
Limited
S_ONL_OBJECT
Y
7.7
OutlookIntegration
Limited
S_MC_OBJ_TYPE
Y
7.7
PSPFactorType
Enterprise
S_PSP_FCTR_TYPE
Y
7.7
PSPValueMap
Enterprise
S_PSP_VAL_MAP
Y
7.7
PerformanceFormula
Limited
S_IC_PFMS_FRMLA
Y
7.7
PersonResponsibility
Limited
S_PER_RESP
Y
7.7
PostnCon
Limited
S_POSTN_CON
Y
7.5
ProductDefectProductLine
Limited
S_PRDFCT_PRODLN
Y
7.7
Enterprise
S_PRDFCT_PRODLN
Y
7.7
Quick Fill
Limited
S_QF_TMPL
Y
7.7
RecurringSchedule
Enterprise
S_RCRNG_SCHED
Y
7.7
Region
Limited
S_REGION
Y
7.7
RetroProcess
Private
S_IC_RETRO_PROC
Y
7.7
SMQ Administration
Limited
S_SMQ_MSG_OBJ
Y
7.7
SMQ History
Limited
S_SMQ_HISTORY
Y
7.7
Server Domain
Limited
S_SERVER_DOMAIN
Y
7.7
Server Domain Engine
Private
S_SD_ENG_IDEN
Y
7.7
Server Domain List of Value
Limited
S_SD_PIM_LIC
Y
7.7
Server Domain PIM RowId Map
Private
S_SD_PIM_ROW
Y
7.7
Server Domain Profile
Limited
S_SD_PIMSV_CFG
Y
7.7
Server Domain Recurrence
Private
S_SD_REPEAT
Y
7.7
Server Domain SEBL RowId Map
Private
S_SD_SEBL_ROW
Y
7.7
Server Domain Server Profile
Private
S_SD_SV_PROFILE
Y
7.7
Server Domain Translation Map
Limited
S_SD_TRANSL_MAP
Y
7.7
Server Domain User Map
Private
S_SD_USER_MAP
Y
7.7
ServerTaskMsg
Private
S_SRVR_TASK_MSG
Y
7.5
Service Region
Enterprise
S_SRV_REGN
Y
7.7
Service Region
Limited
S_SRV_REGN
Y
7.7
ServiceRegionBusinessUnit
Limited
S_SRV_REGN_BU
Y
7.7
ShippingCalcMatrix
Enterprise
S_SHIPCALC_MTRX
Y
7.7
Sort Character
Private
S_SORT_CHAR
Y
7.7
StandardEntlMatrix
Limited
S_STDENTL_PMTRX
Y
7.7
StandardProdMatrix
Limited
S_STDPROD_PMTRX
Y
7.7
StandardTrngMatrix
Limited
S_STDTRNG_PMTRX
Y
7.5
Task Based Process
Limited
S_TASK_PROCESS
Y
7.7
Task Based Process
Limited
S_TASK_DEFN
Y
7.7
VOD
Limited
S_VOD
Y
7.7
VODCacheSync
Private
S_VOD_CACHESYNC
Y
7.7
ValidationMessage
Private
S_ISS_VALDN_MSG
Y
7.7
Workflow Batch
Private
S_WFA_BATCH_JOB
Y
7.7
Workflow Definition
Limited
S_WFA_DPLOY_DEF
Y
7.7
Workflow Definition Log
Private
S_WFA_DEFN_LOG
Y
7.7
Workflow Instance Log
Private
S_WFA_INST_LOG
Y
7.7
Workflow Instance Step Log
Private
S_WFA_INSTP_LOG
Y
7.7
Workflow Runtime
Private
S_WFA_INSTANCE
Y
7.7
Workflow StepProp Log
Private
S_WFA_STPRP_LOG
Y
7.7
ePortalTemplate
Private
S_PAGE_ITEM_SET
Y
Siebel Remote and Replication Manager Administration Guide
