Siebel Remote and Replication Manager Administration Guide > Administering Siebel Remote > Monitoring Siebel Remote Operations >
Monitoring Mobile Web Client Status
You can use views in the Administration - Siebel Remote screen to monitor the status and progress of Mobile Web Clients. This topic discusses the following views:
  • Client Status View
  • Client Diagnostics View
  • Synchronization Sessions View
  • Upload Statistics View
  • Download Statistics View
Using the Client Status View
The Client Status view displays the current status of Mobile Web Clients, including:
  • The last time each Mobile Web Client synchronized
  • The product versions on each Mobile Web Client
  • The last time each Mobile Web Client was extracted and initialized
  • Free Disk (Bytes)
Siebel Remote updates the data in this screen at the start and end of each synchronization session. However, the data in this screen is not updated in the following two cases:
  • During an initialization
    The Free Disk (Bytes) field will also be reset to zero during dbxtract.
  • After applying changes to the client database, if those changes are applied after data transfers are complete
In both cases, the actions occur after the Mobile Web Client disconnects from the server. Therefore, the data in the status screen is not updated until the next synchronization session. At that time, users can check this information to help avoid running out of disk space on their laptops.
When using Siebel Anywhere, the following occurs: the Product Versions field is not populated until the Mobile Web Client upgrades to another version. Once the upgrade is complete, the Product Versions field is updated with the version information after the next synchronization session.
To use the Client Status view
  1. From the application-level menu, choose Navigate > Site Map > Administration - Siebel Remote.
  2. In the link bar, select Client Status.
  3. In the Mobile Clients/Replication Servers list, select the Mobile Web Client that you want to monitor.
    The fields in the Siebel Remote Client Status form provide details about the status.
    Field
    Description
    Extracted on Server
    Last Sessions
    Time when the extract for this client was done
    Seconds
    Time it takes to extract the client
    File name
    First file name for the extracted records
    Rows extracted
    Row count of extracted records
    Snapshot (Kbytes)
    Total size in kilobytes for extracted records
    # of Files in File System
    Number of files in file system for this client
    File System (Kbytes)
    Size of files in file system, in kilobytes
    Max Transaction
    Maximum transaction ID when this client was extracted
    Initialized on Client
    Last Session
    Time when the local database initialization was done
    Seconds
    Time it takes to initialize the local database
    Free Disk (Kbytes)
    Free disk space available on the mobile client's laptop drive
    Database (Kbytes)
    The size in kilobytes of the local database
    Number of files in local file system
    Total size in kilobytes of files in local file system
    Product Version
    System information for the machine where local database resides
    Current status
    Last Session
    Time of the last synchronization session
    Seconds
    Duration of the last synchronization session
    Free Disk (Kbytes)
    Free disk space available on the Mobile Web Client's laptop drive
    Database (Kbytes)
    Current size of the local database
    Number of files in the local file system
    Current size in kilobytes of files in the local file system
    Total Sessions
    Total number of times this client has synchronized so far
    Product Version
    Current system information for the client machine
Using the Client Diagnostics View
The Client Status Diagnostics view provides data routing information about the processors, mobile clients, and regional nodes. Table 18 lists and describes the fields on the Siebel Remote Client Diagnostics form.
Table 18.  Fields on Siebel Remote Client Diagnostics Form
Field
Description
Name
Node name
Type
INIT, ROUTE, RECEIVE, MERGE, CLEAN, SESSION
Local
Flag to show whether it is for current or remote databases
Created
Creation time for the record
Last updated
Last update time for the record
Last file
Last file number processed for the node
Last transaction id
Last transaction number processed for the node
Last trxn duration (sec)
Time it took to process transaction in the latest session
Total duration (sec)
Total Time it took to process transaction for the node
Last trxn size (bytes)
Size of transactions processed for the node during last session
Total (bytes)
Total size of transactions processed for the node
Last trxn operations
Number of operations processed for the node during last session
Total operations
Total number of operations processed for the node
Last transactions
Number of transactions processed for the node during last session
Total transactions
Total number of transactions processed for the node
Total attachment (bytes)
Total size of file attachments processed for the node
Total attachments
Total number of file attachments
Last attachment (bytes)
Size of file attachments for the node during last session
Last attachments
Number of file attachments for the node during last session
Additional information
More detailed information for the node
Using the Synchronization Sessions View
The Synchronization Sessions view displays information about every mobile user and each user's synchronization session for a given period of time. This can be accessed only by the Systems Administrator.
To use the Synchronization Sessions view
  2. In the link bar, select Synchronization Sessions.
  3. In the Synchronization Period form, select the time frame for the period of time you are investigating.
  4. In the Mobile Users list, select the Mobile Web Client that you want to examine.
  5. In the Synchronization Sessions list, run a query using the appropriate values for the fields.
    See Table 19 for descriptions of the fields in this list.
Information displayed on the form and two list applets includes:
  • Synchronization period with From and To fields. Required.
  • Mobile users and the Application server for each.
  • Synchronization session details.
Table 19.  Fields in Synchronization Sessions List
Field
Description
Synchronization Starts
Date and time when the synchronization session started.
Synchronization Ends
Date and time when the synchronization session ended. This will be empty if the synchronization session did not complete successfully.
Transactions
The number of transactions replicated to the mobile user during the session.
Transaction Size (MB)
The total size in MB of the transactions replicated to the mobile user during the session.
Client Merge Duration (Min)
Time (minutes) taken to merge transactions on client.
Using the Upload Statistics View
The Upload Statistics view displays information about transactions and attachment files that are:
  • Created on each Mobile Web Client
  • Received on the server
  • Applied to the server
To check that transactions are made to the server after the client synchronizes, use this screen to verify the last set of transactions sent from the client to the server, and the last transaction applied to the server.
To use the Upload Statistics view
  2. In the link bar, select Upload Statistics.
Table 20 gives descriptions of the fields on the Siebel Remote Upload Statistics form. View the appropriate column on the form to see statistics for items created on the client, items received on the server, or items applied on the server.
Table 20.  Fields on Siebel Remote Upload Statistics Form
Field
Description
Last Session
Duration of the last synchronization session.
Last File
Last transaction file created on the client, received on the server, or applied on the server.
Last Transaction
Last transaction created on the client, received on the server, or applied on the server.
Transaction Count - Last
Number of transactions created on the client, received on the server, or applied on the server during the last synchronization session.
Transaction Count - Total
Total transactions created on the client, received on the server, or applied on the server since the last database extract.
Operation Count - Last
Number of operations created on the client, received on the server, or applied on the server during the last synchronization session.
Operation Count - Total
Total number of operations created on the client, received on the server, or applied on the server since the last database extract.
KBytes - Last
Size of transactions created on the client, received on the server, or applied on the server during the last synchronization session, in kilobytes.
KBytes - Total
Size of transactions created on the client, received on the server, or applied on the server since the last database extract, in kilobytes.
Duration (Seconds) - Last
Duration of last synchronization session created on the client, received on the server, or applied on the server, in seconds.
Duration (Seconds) - Total
Total duration of all synchronization sessions since the last database extract, in seconds.
Attachment Files - Last
Number of attachment files created on the client, received on the server, or applied on the server during the last synchronization.
Attachment Files - Total
Number of attachment files created on the client, received on the server, or applied on the server since the last database extract.
Attachment Size (KBytes) - Last
Size of attachment files created on the client, received on the server, or applied on the server during the last synchronization session, in kilobytes.
Attachment Size (KBytes) - Total
Size of files created on the client, received on the server, or applied on the server since the last database extract, in kilobytes.
Using the Download Statistics View
The Download Statistics view displays information about transactions and attachment files that are:
  • Created on the server
  • Received on the client
  • Applied to the client
To use the Download Statistics view
  2. In the link bar, select Download Statistics.
Table 21 describes the fields on the Siebel Remote Download Statistics form. View the appropriate column on the form to see statistics for items created on the server, items received on the client, or items applied on the client.
Table 21.  Fields on Siebel Remote Download Statistics Form
Field
Description
Last Session
Date and time of last session created on the server, received on the client, or applied on the client.
Last File
Last transaction file created on the server, received on the client, or applied on the client.
Last Transaction
Last transaction created on the server, received on the client, or applied on the client.
Number of transactions created on the server, received on the client, or applied on the client during the last synchronization session.
Total transactions created on the server, received on the client, or applied on the client since the last database extract.
Number of operations created on the server, received on the client, or applied on the client during the last synchronization session.
Total number of operations created on the server, received on the client, or applied on the client since the last database extract.
KBytes - Last
Size of transactions created on the server, received on the client, or applied on the client during the last synchronization session, in kilobytes.
KBytes - Total
Size of transactions created on the server, received on the client, or applied on the client since the last database extract, in kilobytes.
Duration of last synchronization session, in seconds.
Total duration of all synchronization sessions since the last database extract of the node, in seconds.
Attachment File Count - Last
Number of attachment files created on the server, received on the client, or applied on the client during the last synchronization.
Attachment File Count - Total
Number of attachment files created on the server, received on the client, or applied on the client since the last database extract of this node.
Size of the file attachments created on the server, received on the client, or applied on the client during the last synchronization session.
Size of all file attachments created on the server, received on the client, or applied on the client since the last database extract of this node.
