Siebel Remote and Replication Manager Administration Guide > Siebel Remote Concepts > Using Siebel Remote > About Extracting a Mobile Web ClientThe first step in creating a local database for a new mobile user is to extract the database on the Siebel Remote server. Extract Mobile Web Clients by running the Database Extract component. This component extracts visible data for the mobile user into a snapshot file in the Mobile Web Client's outbox directory on the Application server. NOTE: Each local database is a different entity. Therefore, a user cannot use multiple machines as the same Remote client. |
Siebel Remote and Replication Manager Administration Guide |
