Siebel Remote and Replication Manager Administration Guide > Siebel Remote Concepts > Using Siebel Remote > About Initializing the Local DatabaseWhen users log in and specify the Local database as the data source the first time, Siebel Remote will detect that a local database does not exist. This prompts the user to connect to the Siebel Remote server in order to retrieve it. This process performs the following tasks:
Figure 5 shows the processes that occur when a local database is initialized. For additional details on initializing the Mobile Web Client database, see Initializing a Mobile Web Client Database. NOTE: In order to load the Mobile Web Client faster, you can enable Siebel QuickStart. Check the box titled Enable Siebel QuickStart on the Siebel Login Screen for the Mobile Web Client. Siebel.exe will be preloaded to the memory at the system login time. Then every subsequent client session will call the existing process instead of creating a new one, until the user disables QuickStart. For more information about QuickStart, see Siebel Mobile Web Client and Siebel QuickStart. |
Siebel Remote and Replication Manager Administration Guide |
