Siebel Remote and Replication Manager Administration Guide > Administering Siebel Replication Manager >
Adding Connected Users to a Regional Node
This section describes how to add users to the Regional Node. Before adding users to a Regional Node they must be added to the Parent Node. See Applications Administration Guide for adding users to the system.
To add connected users to a Regional node
  1. Make sure the user is a connected user at the HQ node.
  2. From the application-level menu, choose Navigate > Site Map > Administration - Siebel Remote.
  3. In the link bar, select Replication Servers.
  4. On the Parent Server form, select the parent server of the appropriate regional node.
    This may be HQ or a regional node that is also a parent node.
  5. In the Regional Databases list, select the Regional Database you desire.
  6. On the Users field, click the select button.
  7. In the Database Users Selection Dialog box, click New and select the user you want, and then click Add.
  8. Repeat Step 7 until you have added all necessary users, then click OK.
  9. Create user access accounts on the regional node (db accounts or other external Directory Services such as LDAP). For more information about this topic, see Security Guide for Siebel eBusiness Applications.
    Wait for a few hours (depending on your network and hardware configurations) to make sure that all new user data is replicated to the regional node.
