Table 30. Parameters for Replication Agent
Default Value and Usage Notes |
HQ |
The Dock Connect String of the parent Siebel Server. |
Required |
The format is the same as for the Dock Connect String: machine_name: network_protocol:sync_port: service:encryption where machine_name identifies the parent Siebel Server and sync_port identifies the synchronization port number. Available choices are: network_protocol: TCPIP sync_port: 40400, Any service: SMI encryption: None, MSCRYPTO, RSA Default for Sync Port: 40400 Default for Encryption: None |
Comm Param |
The colon-separated list of communications parameters used to connect to the parent Siebel Server. |
Optional |
This parameter is not used. |
SleepTime |
The period (in seconds) for which Replication Agent should sleep between synchronization sessions. |
Optional |
Default: 60 |
MaxWrite |
Used to limit the size of a DX file—that is, to break DX files to be sent to the parent Siebel Server into smaller, more manageable pieces. Replication Manager closes the existing DX file and starts writing to a new DX file when the current DX file reaches the maximum number of operations specified with this parameter. |
Optional |
Default: 10000 |
SendTxns |
Sends DX files from the Regional Server to the parent Siebel Server. If this parameter is set to FALSE, Replication Manager does not send DX files from the Regional Server to the parent Siebel Server. |
Optional |
Default: TRUE |
RecvTxns |
Receives DX files sent by the parent Siebel Server to the Regional Server. If this parameter is set to FALSE, Replication Manager does not receive DX files sent by the parent Siebel Server to the Regional Server. |
Optional |
Default: TRUE |
RecvFiles |
Receives file attachments sent by the parent Siebel Server to the Regional Server. If this parameter is set to FALSE, Replication Manager does not receive file attachments sent by the parent Siebel Server to the Regional Server. |
Optional |
Default: TRUE |
Iterations |
Specifies the number of times that Replication Agent will connect to the parent node. Typically, this parameter is set to zero (0), and the Replication Agent loops forever (or until stopped by the server administrator). If you set this parameter to 1 and start Replication Agent, this causes a single synchronization to occur. |
Optional |
Default: 0 |
MaxCommitTxns |
Specifies how many transactions will be applied before they are committed to the database. |
Optional |
Default: 100 |
