Security Guide for Siebel Business Applications > Configuring Access Control > Administering Access Control for Business Services > Disabling Access Control for Business ServicesEnabling access control for business services can have an effect on response times for your Siebel Business Applications. If you do not require access control for business services (that is, you only require prerelease 7.8 access control functionality), you can disable it at the component level for a specific application. To disable access control for business services, you set the parameter OM - Enable Resource Access Control = FALSE for the selected component. The following procedure demonstrates how to set the value for OM - Enable Resource Access Control. NOTE: The default value for OM - Enable Resource Access Control is True. To disable access control for business services
Security Guide for Siebel Business Applications |
