Security Guide for Siebel Business Applications > Configuring Access Control > Clearing Cached ResponsibilitiesA particular responsibility is cached when a user logs in who has that responsibility. Users have access only to those views that were defined for applicable responsibilities at the time they logged in, even though additional views may have been added by an administrator since that time. If you add, delete, or modify a responsibility in the Responsibilities view (Responsibilities List View), you can clear the cache in order to instruct the Siebel application to read updated values from the database. Clearing the cache makes these changes available to users who log in subsequently or who log out and log in again. The Siebel Server does not need to be restarted. |
Security Guide for Siebel Business Applications |
