Security Guide for Siebel Business Applications > Communications and Data Encryption > Configuring Secure Communications > Configuring Encryption for Mobile Web Client SynchronizationYou can enable encryption for Mobile Web Client synchronization. During this synchronization, DX files are transferred between the Siebel Server and Mobile Web Clients. DX files use SISNAPI messages to transfer information between the Siebel Server and Mobile Web Clients. The Siebel Mobile Web Client reads configuration parameters in the Siebel application configuration file (for example siebel.cfg, used by Siebel Sales) to determine the type of encryption to use during synchronization. Encryption options are defined as one of the elements in the NOTE: Secure Sockets Layer (SSL) is not a supported encryption method for the Siebel Developer Web Client or for synchronization of the local database on the Siebel Mobile Web Client. For information about authentication for Siebel Mobile Web Client and Siebel Remote, see Authentication for Mobile Web Client Synchronization. For information about other security issues for Siebel Mobile Web Client, including encrypting the local database, see Siebel Remote and Replication Manager Administration Guide. To enable encryption of synchronization on the Mobile Web Client
Security Guide for Siebel Business Applications |
