Security Guide for Siebel Business Applications > Web Single Sign-On Authentication > Setting Up Web SSO: A Scenario >
Editing Parameters in the Application Configuration File
Provide the parameter values as indicated by the guidelines in Table 17 in the configuration file for the Siebel application you are implementing. For a list of Siebel application configuration files, see Siebel System Administration Guide.
For information about editing an application's configuration file and about the purposes for the parameters, see Siebel Application Configuration File Parameters.
Table 17. Siebel Application Configuration File Parameter Values
Guidelines for ADSI Security Adapter
Enter TRUE.
NOTE:  If you do not set this parameter to TRUE, browser looping behavior may occur.
Enter TRUE or FALSE. If TRUE, the login form completed by the user is transmitted over a Secure Sockets Layer (SSL). For information about other requirements for secure login, see the secure login topic in Login Features.
