Security Guide for Siebel Business Applications > Web Single Sign-On Authentication > Setting Up Web SSO: A Scenario >
Creating Users in the Directory
Create three users in the directory as described in Table 14. The attribute names, sAMAccountName and Password, are those suggested in this example. Your entries may vary, depending on how you make attribute assignments in Setting Up the Active Directory Server.
Table 14. Directory Records
Anonymous user |
- Enter the user ID of the anonymous user record for the Siebel application you are implementing.
You can use a seed data anonymous user record, as described in Seed Data, for a Siebel customer or partner application. For example, for Siebel Service, enter GUESTCST .
- You can create a new user record or adapt a seed anonymous user record for a Siebel employee application.
GUESTPW or a password of your choice
username=LDAPUSER password=P
Application user |
APPUSER or a name of your choice
APPUSERPW or a password of your choice
A database account is not used for the application user. |
A test user |
TESTUSER or a name of your choice
TESTPW or a password of your choice
The database account for all three users is the same, and must match the database account reserved for externally-authenticated users described in Creating a Database Login. P represents the password in that database account. For information about formatting the database account attribute entry, see Requirements for LDAP/ADS Directory. CAUTION: Make sure the application user has privileges to search and write all records in the directory.
Complete other attribute fields for each user, as needed.
