Security Guide for Siebel Business Applications > User Administration > Implementing Self-Registration > Setting Configuration Parameters for Self-RegistrationThe user directory can be administered through Siebel Business Applications if you implement security adapter authentication. Changes such as adding a user or changing a password by an internal administrator, a delegated administrator, or when a user self-registers are propagated to the user directory. Set the NOTE: If you do not configure your security adapter authentication architecture to allow administration through the Siebel Web Client as described here, then you must manually create a record in the user directory whenever a new user of this application is created in the Siebel Database. |
Security Guide for Siebel Business Applications |
