log. Siebel Gateway Name Server logs. objects. Empty directory. When you install the Siebel Server into the same root directory, that installation procedure populates this directory with a language subdirectory (such as enu for U.S. English) with a corresponding Siebel repository file (siebel.srf). output. Contains files related to Siebel Remote. siebenv.csh. C shell variant of the Siebel script for setting environment variables on the server. siebenv.sh. Bourne shell and Korn shell variant of the Siebel script for setting environment variables on the server. sqltemp. Empty directory. When you install the Siebel Server into the same root directory, that installation procedure populates this directory with SQL files, containing SQL templates that can be used to create SQL statements the Siebel Server will use to perform specific database operations. sys. The backing files and Service entry files used by the Siebel Gateway Name Server and server control utilities. Do not edit or modify these files unless instructed to do so by Siebel Technical Support. temp. Stores temporary files generated by the Siebel Gateway Name Server. upgrade. Files and scripts related to version upgrades of Siebel Business Applications. Also holds temporary, backup, and state log files used during an upgrade. upgrade.log. Upgrade log file. |
