Siebel Installation Guide for UNIX: Servers, Mobile Web Clients, Tools > Installing the Siebel Reports Server > Installing the Siebel Report Design Products >
Installing Actuate e.Report Designer
Actuate e.Report Designer lets developers for the Windows platform design and create reports, using its graphical user interface.
Installation of Actuate e.Report Designer is not required to run the Siebel Reports Server.
If you install Actuate e.Report Designer, you must install it on a developer machine that has Siebel Tools installed on it.
NOTE:  The following procedure is for installing the base product. For patch installation instructions, refer to the Maintenance Release Guide provided with the patch. See also About Installing Siebel Releases.
To install Actuate e.Report Designer
  1. In Windows Explorer, navigate to the Siebel image location for the current software version. Then navigate to the directory where the installer is located.
    In this case, navigate to Siebel_Image\Windows\Client_Ancillary\Siebel_Reports_Client\language\erd.
    • Siebel_Image = The directory for your version-specific Siebel network image, such as D:\Siebel_Install_Image\
    • language = The Siebel code for the Language Pack you installed; for example, enu for U.S. English.
  2. Double-click setup.exe.
    The Actuate installation wizard will guide you through the installation process.
