Siebel Installation Guide for UNIX: Servers, Mobile Web Clients, Tools > Installing the Siebel Web Server Extension > Postinstallation Tasks for the SWSE > Configuring Sun Java System Web Server to Accept the SWSEFor the Sun Java System Web Server (formerly Sun ONE Web Server) running under the Solaris operating system, you must configure the Web server to accept the changes that the SWSE installer makes to the Web server configuration files after you install SWSE. Otherwise, changes that you may make in the future to the Web server configuration will overwrite the changes made by the Siebel installation script. To make sure that Sun Java System Web Server accepts changes made by SWSE
Sun Java System Web Server References to the eapps.cfg FileDuring installation, the Siebel installer adds a reference to the Sun Java System Web Server configuration file magnus.conf. This file specifies global settings of the Web server, such as server information, object file configuration, DNS lookup, ACL, and so on. A typical line the installer would add to magnus.conf might resemble the following example: Init fn="swe-init" config-file=" |
Siebel Installation Guide for UNIX: Servers, Mobile Web Clients, Tools |
