Siebel Installation Guide for UNIX: Servers, Mobile Web Clients, Tools > Installing the Siebel Server > Managing Load Balancing for Siebel Applications > Monitoring Servers with Third-Party HTTP Load BalancersMost third-party HTTP load balancers support server health monitoring. To set up Siebel Server monitoring, configure the load balancer to send an HTTP GET to the server URL. Here is an example URL: //SiebSrvr1:2321/sieb78/SCBroker
If the Siebel Server and Siebel Connection Broker are running, Siebel Connection Broker returns the string: This confirms that the Siebel Server is running on the specified platform and that SCBroker is listening at the specified port. This health check does not verify that specific Application Object Managers (AOMs) or other server components are running on the platform. CAUTION: Do not use TCP Health Check. It may connect to SCBroker and remain connected. This causes SCBroker to wait until the SCBroker component parameter Best Practices for Setting Up MonitoringImplement the following best practices when you set up server monitoring:
Siebel Installation Guide for UNIX: Servers, Mobile Web Clients, Tools |
