Siebel Installation Guide for UNIX: Servers, Mobile Web Clients, Tools > Installing in Unattended and Console Modes >
Additional Flags for Installation Commands
You can optionally append any of the following flags to your installation command:
-is:log logfile
where:
logfile = The full path name and the name of the file to be generated (for example, /usr/tmp/gateway.log)
Generates an additional log file. The logging information in the file is limited to initialization errors, such as JVM. Use this flag for debugging or for troubleshooting when you cannot invoke the installation process.
NOTE: The default log file that records status errors during installation is created in the $SIEBEL_ROOT directory.
-is:javaconsole -console
Generates a script-type (non-GUI) installation. This method is most useful when installing over a WAN. For more information, see Installing and Configuring in Console Mode.
-is:tempdir temp _directory_location
Directs the installer to the location to install the temporary files. If the default directory is not suitable or does not have the required free space, you can designate another location. For more information, see Managing Temporary Disk Space Required by Installers.
