Siebel Installation Guide for UNIX: Servers, Mobile Web Clients, Tools > Installing in Unattended and Console Modes > Installing in Unattended Mode >
Editing siebel.ini Files for Unattended Configuration of Individual Servers
Follow this procedure for unattended configuration of individual modules such as Siebel Gateway Name Server or Siebel Server. To modify the siebel.ini file for individual server configuration
- Using a text editor, modify the appropriate siebel.ini file or files as listed below:
NOTE: Make a copy of each siebel.ini file you plan to modify, and save it in a unique location that identifies the module it pertains to. Preserve these copies in case you may need them for later reference.
- Set all keys in the
[Dialog.Config] section to no .
- Locate
[Behavior] section and set Silent to yes . This logs all errors instead of displaying them.
- Set all values in
[Defaults.Config] to the appropriate values.
The PrimaryLanguage and OMLanguages entries should be set to the three-letter language code (lowercase) for the desired language. For example, you should add PrimaryLanguage = enu for U.S. English. Language codes are listed at the end of the siebel.ini file. For more information about these parameters, see Table 14.
NOTE: For configuration values, refer to Sample Parameter Values for siebel.ini Files for Unattended Configuration.
