Siebel Installation Guide for UNIX: Servers, Mobile Web Clients, Tools > Configuring the RDBMS > Configuring Oracle for Siebel Applications >
Guidelines for Ongoing Oracle Administration
After your Siebel Business Applications installation is up and running, monitor the following areas on a regular basis:
- Insertion rates on tables. You will probably want to set the
INI_TRANS value for tables with high insertion rates to a value higher than 1; a typical setting is 4.
This parameter determines how many simultaneous inserts can occur on the database blocks that store data for those tables and, therefore, can affect performance in an intensive data-entry environment. Use multiple freelists for the table S_DOCK_TXN_LOG , because this table receives numerous inserts.
- SGA cache hits. Determine whether SGA parameters need to be adjusted for your system.
- The extents used by each object. A large number of extents on a table or index creates response time degradation for transactions that access the table or index.
- Siebel tables that are subject to frequent INSERT and DELETE operations. This transaction mixture can cause some databases to become fragmented over time.
If you are using Siebel Remote, your Database Administrator should monitor the space utilization and fragmentation of the tables listed below, and perform regular database maintenance procedures as recommended by your database vendor. Monitor the following tables, in particular, because they will have frequent changes when transaction logging is enabled:
S_DOCK_TXN_LOG S_DOCK_TXN_LOGT S_DOCK_TXN_SET S_DOCK_TXN_SETT S_DOCK_INST S_DOCK_INIT_ITEM
Your Database Administrator may also choose to monitor all tables and indexes in the Siebel Schema, reorganizing them when required.
- Rollback segments. Make sure that you have enough segments available and that they are the optimum size for the most common operations.
