Siebel System Administration Guide > Configuring Siebel Servers > Configuring the Siebel Enterprise Server > Synchronizing Components on a Siebel Enterprise ServerThis topic describes synchronizing components on a Siebel Enterprise Server. You need to synchronize batch-mode Siebel Server components between the Siebel Gateway Name Server and the database whenever you:
NOTE: If synchronization does not take place, make sure the LOV (List of Value) type SRM_ACTION_TYPE is set to active. See Applications Administration Guide for details on working with LOVs. For information on other Siebel Enterprise Server configurations, see Configuring the Siebel Enterprise Server. To synchronize components on a Siebel Enterprise Server
Siebel System Administration Guide |
