Siebel System Administration Guide > Configuring Siebel Servers > Configuring the Siebel Enterprise Server >
Configuring Component Job Templates
This topic describes configuring a component job template, which can be used on Siebel Servers across an enterprise. A component job template is a predefined component job that uses parameter values you have defined. You should use component job templates instead of individual component jobs if you are planning to regularly run component jobs with the same parameter values. For further information on component jobs, see Administering Component Jobs.
For information on other Siebel Enterprise Server configurations, see Configuring the Siebel Enterprise Server.
To define a component job template
  1. From the application-level menu, choose Navigation > Site Map > Administration - Server Configuration.
  2. From the link bar, click Job Templates.
  3. In the Job Templates list, click the New button.
  4. In the Name field, type in a descriptive name for the component job, such as Monthly EIM.
  5. In the Short Name field, type in an alias for the component job, such as MonthEIM.
  6. In the Component field, select the component that will be used for this component job, such as Enterprise Integration Manager.
    NOTE:  After a component job is created, do not change the value of the Component field. To change the component for an existing component job, create a new component job instead of modifying the existing one.
  7. In the Description field, type in a description of the component job.
  8. In the lower list, click the New button.
  9. In the Name field, select the parameter you would like to define for this component job.
    1. In the Name field, click the select button.
      The Component Parameters dialog box appears. The parameters that appear in the Component Parameters dialog box vary depending on the component you selected in Step 6.
    2. In the Component Parameters dialog box, click Query.
    3. In the Name field, type in the name of the parameter and click Go.
    4. Click OK.
  10. In the Value field, type in the value for the parameter.
    The default value is automatically displayed in this field.
  11. Check the appropriate flags for this parameter. To set the parameter type, use the following flags:
    • For fixed parameter, check the Fixed Flag field.
    • For required parameter, check the Required Flag field.
  12. Click the menu button and then click Save Record.
  13. Continue to choose parameters by completing Step 8 through Step 12 until you have defined the parameters for the component job.
