Siebel System Administration Guide > Configuring Siebel Servers > Process for Creating a Custom Siebel Server Component >
Disabling a Siebel Server Component Definition
This topic describes the procedure for disabling a custom Siebel Server component definition.For further information on component definitions, see About Siebel Server Component Definitions.
To disable a Siebel Server component definition
  1. From the application-level menu, choose Navigation > Site Map > Administration - Server Configuration.
  2. Click the Component Definitions view tab.
  3. In the Component Definitions list, select the component definition of interest.
  4. Click the Disable button.
    The component definition state field changes to Inactive.
  5. For the change to take effect, stop and restart the Siebel Server System Service.
    For information on this procedure, see Administering the Siebel Server System Service.
