Siebel System Administration Guide > Configuring Siebel Servers > Advanced Configuration Tasks >
Deleting System Parameter Overrides
By default, lower-level system parameters inherit values from the same higher-level system parameters. However, modifying a lower-level parameter value also sets an override at this level; that is, the lower-level parameter loses the ability to inherit values from higher-level parameters. To reinstate this default functionality, configure the delete parameter override feature on affected parameters.
For further information on system parameters and system parameter hierarchy, see About Siebel Server Parameters.
You can configure the delete parameter override feature from:
To delete parameter override for Siebel Enterprise Server parameters
  1. From the application-level menu, choose Navigation > Site Map > Administration - Server Configuration.
  2. From the link bar, click Enterprises.
  3. Click the Parameters view tab.
  4. In the Enterprise Parameters list, select the parameter of interest.
  5. Click the menu button, then Delete Parameter Override.
To delete parameter override for Siebel Server parameters
  2. From the link bar, click Servers.
  4. In the Server Parameters list, select the parameter of interest.
To delete parameter override for component definition parameters
  3. Click the Component Definitions view tab.
  4. In the Component Parameters list, select the parameter of interest.
To delete parameter override for Siebel Server component parameters
  3. Click the Components view tab and select the component of interest.
  4. Click the Parameters view tab below the Components view tab.
  5. In the Component Parameters list, select the parameter of interest.
  6. Click the menu button, then Delete Parameter Override.
