Testing Siebel Business Applications > Design and Develop Tests > Test Case Automation > Performance AutomationAutomation is necessary to conduct a successful performance test. Performance testing tools virtualize real users, allowing you to simulate thousands of users. In addition, these virtual users are less expensive, more precise, and more tolerant than actual users. The process of performance testing and tuning is iterative, so it is expected that a test case will be run multiple times to first identify performance issues, and then verify that any tuning changes have corrected observed performance issues. Performance testing tools virtualize real users by simulating the HTTP requests made by the client for the given scenario. The Siebel 7 Smart Web Architecture separates the client-to-server communication into two channels, one for layout and one for data. The protocol for the data channel communication is highly specialized; therefore Siebel Systems has worked closely with leading test vendors to provide their support for Siebel 7. Because the communication protocol is highly specialized and subject to change, it is strongly recommended that you use a validated tool. At a high level, the process of developing automated test scripts for performance testing has four steps. Please refer to the instructions provided by your selected tool vendor for details:
Siebel Systems offers testing services that can help you design, build, and execute performance tests if you need assistance. Best PracticeUsing test automation tools can reduce the effort required to execute tests, and allows a project team to achieve greater test coverage. Test Automation is critical for Performance testing, because it provides an accurate way to simulate large numbers of users. |
Testing Siebel Business Applications |
