Testing Siebel Business Applications > Functional Test Object Reference >
Common Test Automation Object Properties
The following table provides descriptions of common properties available from multiple test automation objects.
Property Name
Type
Description
ClassName
String, Const String
The name of the class of the test automation object.
Count
Integer
The number of objects of a given type that are present in the current context.
IsEnabled
Boolean
A Boolean value that indicates whether or not the object is enabled.
IsOpen
Boolean
A Boolean value that indicates whether or not the object is open. This property is used in objects that have a popup applet.
IsRequired
Boolean
A Boolean value that indicates whether or not the object is required.
RepositoryName
The name of the object as it is stored in the repository of the test automation tool.
Text
String
The text value of the object.
UIName
The name of the object as it is displayed in the user interface.
