Testing Siebel Business Applications >
Functional Test Object Reference
The test objects described in this section represent the API for Siebel Test Automation. You can use these objects to compose functional test scripts that you execute using your automated testing tool. For more information on functional testing in Siebel applications, see Execute Siebel Functional Tests and Automating Functional Tests. For information about writing and running test scripts, see the documentation that accompanies your test tool.
The following topics are included in this section:
NOTE:  The API for Siebel Test Automation is controlled by a license key. You must obtain and enter a license key for Siebel Test Automation before using the API.
