Testing Siebel Business Applications > Automating Load Tests > Troubleshooting Load Testing IssuesThis section provides tips for resolving common issues associated with recording and running automated load test scripts. NOTE: The causes and fixes described for these common issues are those that are most often encountered. However, they might not be the only such causes or fixes. The following issues are addressed:
Back or Refresh ErrorThe Siebel application displays an error applet indicating the following: We detected an Error which may have occurred for on or more of the following reasons: CauseThis issue can be caused by the following conditions:
FixTo resolve this issue, try the following fixes:
If these fixes do not resolve the issue, rerecord the script. No Content HTTP ResponseThe server returns an error like the following: HTTP/1.1 204 No Content CauseThe row ID is not properly correlated. FixManually correlate the row ID. Same Values ErrorThe server returns an error like the following: @0`0`3`3``0`UC`1`Status`Error`SWEC`10`0`1`Errors`0`2`0`Level0`0`ErrMsg`The same values for 'Name' already exist. If you would like to enter a new record, please ensure that the field values are unique.`ErrCode`28591` CauseOne of the values in this request (in the previous code example, it is the value for the Name field) is the same as a value in another row in the database table. FixYou must replace this value with a unique value for each iteration for each user. The recommended solution is to use the row ID parameter for the value; this causes the value to be unique. Restoring the Context ErrorThe server returns an error like the following: @0`0`3`3``0`UC`1`Status`Error`SWEC`9`0`1`Errors`0`2`0`Level0`0`ErrMsg`An error happened during restoring the context for requested location`ErrCode`27631` CauseThe row ID is not properly correlated. FixManually correlate the row ID. Cannot Locate Record ErrorThe server returns an error like the following: @0`0`3`3``0`UC`1`Status`Error`SWEC`23`0`2`Errors`0`2`0`Level0`0`ErrMsg`Cannot locate record within view: Contact Detail - Opportunities View applet: Opportunity List Applet.`ErrCode`27573` CauseThe input name SWERowId does not contain a row ID for a record on the Web page. This input name should have been parameterized. The parameter's source value may have changed its location. FixManually correlate the row ID. End of File ErrorThe server returns an error like the following: @0`0`3`3``0`UC`1`Status`Error`SWEC`28`0`1`Errors`0`2`0`Level0`0`ErrMsg`An end of file error has occurred. Please continue or ask your systems administrator to check your application configuration if the problem persists.`ErrCode`28601` CauseThe input name SWERowId does not contain a row ID for a record on the Web page. This input name should have been parameterized. The parameter's source value may have changed its location. Fix |
Testing Siebel Business Applications |
