Testing Siebel Business Applications > Functional Test Object Reference > SiebList Methods >
GetTotalsValue Method
The GetTotalsValue method returns the value in the totals row of a list control for the specified column. If the specified control does not have a totals row, GetTotalsValue returns an empty string.
Available from
SiebList Object
Syntax
GetTotalsValue (ColumnRepName)
Argument
Description
ColumnRepName
A String that indicates the RepositoryName of the column
Returns
A String indicating the value in the totals row for the specified column, or an empty String if the control does not have a totals row.
