Upgrade Guide > Performing the Siebel Repository Merge > Copying UI Files to a New Siebel EnvironmentUpgrades from: Siebel 7.x using ICL. Also applies to non-ICL upgrades where you have manually revised Web template files or the style sheet file (main.css). Environments: Production test, production. This topic is part of an upgrade process. See How to Perform a Siebel Database Upgrade. ICL UpgradesIf you selected Incorporate Custom Layout (ICL) during the repository merge, a special set of Web template files was copied to the You must copy these files to the Siebel Servers in the production test and production environments. Customized Web Template FilesWhen you customize Web template definitions using Siebel Tools, these changes are stored in the Siebel Repository. Siebel Tools does not make changes to the Web template files located in the Siebel Tools installation directory. If you have manually customized the Web template files in the Siebel Tools installation directory in the development environment, you must copy these files to the Siebel Servers in both the production test and production environments. Copying Style Sheet Files to a Different EnvironmentWhen you customize properties of layout objects such as text fields using Siebel Tools, these changes are stored in the Siebel Repository. Siebel Tools does not make changes to the style sheet file (main.css) located in the Siebel Tools installation directory. If you have manually customized main.css in the Siebel Tools installation in the development environment, you must copy this file to the Siebel Servers in both the production test and production environments. You must also copy main.css to the new environment if you have done the following:
If you performed an ICL upgrade and selected Label on Top, you must also copy the style sheet for Quick Print and Print Preview (printmain.css) to the new environment. To copy style sheet files to a different environment
Upgrade Guide | Copyright © 2006, Oracle. All rights reserved. | |
