Bookshelf Home
Contents
Index
PDF
Upgrade Guide
Performing the Siebel Repository Merge
This area contains the following topics:
Configuring Siebel Repository Objects to Inherit Upgrade Behavior
Configuring Siebel Tools for the Repository Merge
Performing a Siebel Repository Merge
Determining if a Siebel Repository Merge was Successful
Generating Siebel EIM Temporary Columns
Reviewing Siebel Repository Object Property Conflicts
Regenerating the Siebel Repository Definition Files
Moving the Siebel Repository Files
Setting Label Alignment for Siebel Text Fields
Copying UI Files to a New Siebel Environment
Deleting Unneeded Siebel Repository Files
Migrating Siebel Repository Objects to the Standard UI
Running the Siebel Postmerge Utilities
Related Topics
How to Perform a Siebel Database Upgrade
Upgrade Guide
Copyright © 2006, Oracle.
All rights reserved.
