Upgrade Guide > Performing the Siebel Repository Merge > Configuring Siebel Tools for the Repository MergeUpgrades: All Siebel upgrades. Environments: Development environment only. This topic is part of an upgrade process. See How to Perform a Siebel Database Upgrade. The topic applies to the Siebel Tools installation you will use to perform the repository merge. If you are upgrading on Oracle 9i and want to run the development upgrade in Rule Based Optimization (RBO) mode, you must change the value of the SqlStyle parameter in the Siebel Tools configuration file. After the upgrade, you must reset the parameter to the default. Before the Repository mergePerform this task if you plan to run the development environment upgrade in RBO mode. To configure Siebel Tools before the repository merge
After the Repository MergePerform this task to reset the SqlStyle parameter to the default, OracleCBO. To reset Siebel Tools configuration after the repository merge
Upgrade Guide | Copyright © 2006, Oracle. All rights reserved. | |
