Upgrade Guide > Performing the Siebel Repository Merge > Moving the Siebel Repository FilesUpgrades: All Siebel upgrades. Environments: Production test, production. This topic is part of an upgrade process. See How to Perform a Siebel Database Upgrade. Before doing the production test environment upgrade, you must copy the upgraded repository definition files (schema.ddl and custrep.dat) from the development environment to the production test environment. Prerequisite: If you modified repository objects or schema definitions after completing the development upgrade, you must regenerate the schema.ddl and custrep.dat files. See Regenerating the Siebel Repository Definition Files.
Upgrade Guide | Copyright © 2006, Oracle. All rights reserved. | |
